Тема: Саабревиатруры
ABS anti-lock braking system
AC air conditioning (manual)
ACC Automatic Climate Control
Aero Generally denotes the highest performance model in a particular range, eg 9-5 Aero, 9-3 Aero, 9000 Aero. The exception is the 1991-3 C900 Aero, which was
an LPT with an Airflow kit. Also refers to the classic three-spoke alloy wheel design first seen on the C900 Aero.
Airflow On the 99 and C900, denotes the bodykit comprising front and rear bumpers and side cladding. 9-3 and 9-5 Airflow models had the Aero bodykit and suspension, but LPT engines.
Anniversary Last-of-the-line Saab 9000, with unique leather seats and wood/leather steering wheel
AIC Air Idle Control - see also ISCV
ALU** Saab part number for Alloy Wheels eg ALU45
AMM Air Mass Meter, specifically on cars with Bosch / Lucas fuel injection. Measures the flow of air in the intake manifold, and passes the signal to the fuel
injection ECU.
APC Automatic Performance Control. Introduced on the C900 Turbo, the APC uses a knock sensor to detect pre-ignition, and adjusts boost pressure accordingly. This enables the engine to run on any grade of fuel. The precursor to Trionic.
APC Solenoid Electrically-operated valve which allows the APC system to vary turbo boost pressure
AS1 Audio System ‘Popular’. Basic level head-unit and four speakers (GM900, 9-3, 9-5)
AS2 Audio System ‘Premium’. Mid-range head unit, more speakers on the 9-5 (GM900, 9-3, 9-5)
AS3 Audio System ‘Prestige’. Top-level, CD/tape with extra amplifiers and subwoofers, Harman-Kardon on 9-5. (GM900, 9-3, 9-5) (usually optional)
Arc Olde worlde trim level, with wood and leather
ATA Anti Theft Alarm
BDC Bottom Dead Centre, the opposite of TDC
Body in white manufacturer's ***** for the body shell prior to painting or the car's structure
BOV Blow Off Valve. Atmospheric dump valve, not suitable for use on cars with an AMM
BPV By Pass Valve. Recirculating dump valve.
C900 Classic 900, MY79-93
Carlsson Limited-edition, high performance versions of the C900, 9000 and 9000CS. Named after rally-driving ace Erik Carlsson
CBC Cornering Brake Control
CC Combi Coupe ‘hatchback’ bodystyle. First used to identify the 5-door Saab 99. Can also refer to the pre-1992 Saab 9000 5-door hatchback.
CD Taken from ‘Corps Diplomatique’ and used to denote luxurious saloon cars. Saab uses are the 4-door Saab 9000 CD, and the rare stretched 900CD.
CDE See CD, but with better trim levels (usually leather, wood, body coloured bumpers etc)
CDC Compact Disc Changer. Mostly boot-mounted, although also an in-dash option in the 9-3SS. Also CDC6 and CDC10 self-explanatory.
CS Thought to mean ‘Combi Sedan’ - the post-1992 Saab 9000 5-door hatchback.
CSE See CS, but with better trim levels (usually leather, wood, body coloured bumpers etc)
DI Direct Ignition, which does away with the need for a conventional distributor. The DI cassette sits in the cylinder head on top of the spark plugs, with one coil per cylinder. See also IDM
DICE Dashboard Integrated Control Electronics. Controls lighting, heating, wipers etc in the 9-5 and 9-3SS.
Divorce The reversal of ‘marriage’, using Tech II to remove a CDC from a Tech II equipped Saab. Without being ‘divorced’, the changer cannot be used in another car. Divorce requires the presence of both parties - ie the CDC and the car to which it was originally ‘married’.
DRL Daytime Running Lights
DTE Distance to Empty. SID setting showing you how far you can drive before you run out of petrol
EAC Electronic Accessories Catalogue
EBA Emergency Brake assist
EBD Electronic Brake-force Distribution
ECM Electronic Control Module, at the heart of the Trionic system. See also ECU
ECO Ecopower, Saab’s turbo philosophy. Initially applied only to LPT engines but now universal
EGT Exhaust Gas Temperature
ECU Electronic Control Unit
EGR Exhaust Gas Recirculation. An emissions-control measure
EPC Electronic Parts Catalogue
ES1-4 Basic radio in 9-3SS with 4 speakers
ES1-7 Ditto 7 speakers
ES2-7 Middle grade radio 9-3SS 7 speakers
ES2-13 Ditto 13 speakers
ES3-7 Top of range radio in 9-3SS often with Sat Nav
ES3-13 Ditto with 13 speakers
ESP electronic stability programme
Fault Code a code generated by the ECU, pinpointing a specific fault
FCR Fault Code Reader. Used for extracting fault codes from the ECM
FPR Fuel Pressure Regulator (see RRFPR)
Freewheel The system of disengaging the front hubs from the engine during overrun, essential to prevent your two-stroke engine seizing
Fried Egg The appearance of an orange indicator bulb in a clear light cluster
GM General Motors / Genetically Modified
GM900 900 MY94-97. Also NG (Next Generation) 900
Griffin top-of-the-range in ***** of luxury, all the toys you can think of coupled with a V6 (9-5 and 9000) or 2.3FPT (9000 only) engine and automatic gearbox
IDM Ignition Discharge Module - see also DI
Inca the classic Alloy wheel seen on the Saab 99 Turbo. Evolved into the less-attractive Super Inca
ISCV Idle Speed Control Valve. See also AIC
Limp Home Mode see LOS
Linear Basic ‘plastic and cloth’ trim level
LOS Limited Operating Strategy. More commonly referred to as ‘limp home mode’, enabling the vehicle to be safely driven to a workshop / garage for repair following the failure of a crucial component in the Trionic system
LSD Limited Slip Differential. Reduces the likelihood of spinning one front wheel under hard acceleration. The down-side is that you spin both instead.
Marriage Programming a CDC to a particular car using Tech II. Renders the CDC useless if stolen, because it must be ‘divorced’ before being used in another car.
MBC Manual Boost Controller. Another ***** for ‘bleed valve’, which allows manual tweaking and increasing of boost pressure but with the loss of APC protection
Minilite eight-spoke alloy wheel which looks particularly good on the Saab 96
MIU Main Instrument Unit 9-3/5 again, instrument cluster, all electronic.
OBD On Board Diagnostics (OBD 1 and OBD 2, refers to the ECU's ability to self-diagnose)
OnStar US Only Built-in mobile ‘phone / sat-nav
Vovlo Saab’s main competitor
RDS Radio Data System (on radio display in SID) a programme that stays tuned in as you drive (not USA)
ReAXS Saab's passive rear wheel steering on 9-3SS
RPM Revolutions Per Minute. Engine speed.
RRFPR Rising Rate Fuel Pressure Regulator. Increases fuel pressure as engine rpm rises
SAAB Svenska Aeroplan Aktiebolaget
SAAB Saab Automobile Aktiebolaget
Saabaru The Saab 9-2X, a Subaru Impreza with a Saab nose grafted on.
SAHR Saab Active Head Restraints. These move forward in the event of an accident, to reduce whiplash.
SCC Saab Car Computer. Precursor to the SID (9000)
Semisonic ‘Indie’ band who did ‘Have a Nice Day’
Sensonic Semi-automatic gearbox in GM900
Sentronic Automatic gearbox with optional manual / paddle shift (9-5 and 9-3SS only)
SID Saab information display. Comes in different flavours, eg SID1 (basic), SID2 (more functions), SID3 (all the functions)
SPA Saab Park Assist
SPG Special Performance Group (North American C900 Turbo, similar to the European Aero)
SRS supplementary restraint system (ie airbags)
SS Sport Saloon / Sedan. As in the 9-3 Sport Saloon, M03
Subaraab see Saabaru
Talladega Limited edition models of the 9000 and NG900, named after Saab’s endurance records set at the Talladega Raceway in 1986 (9000) and 1996 (NG900). The 9000 Talladega was analogous to the UK-only 9000 Carlsson, whilst the 900 Talladega gained extra equipment with various engine options.
TCM Transmission Control Module, same as ECU but for auto box
TCS Traction Control System. Limits wheelspin by reducing power appropriately. Can be troublesome on the 9000.
TDC Top Dead Centre, the point at which the piston is at the top of its travel, closest to the cylinder head
Tech 2 Saab’s proprietary on-board diagnostic computer
TiD Turbo injection Diesel
Tjugofem Limited edition C900 produced in 1985 to mark 25 years of the sale of Saab cars in the UK (Swedish: 'Tjugofem': Tjugo = Twenty, fem = five)
TP Traffic Programme (on radio display in SID)
TWICE Theft Warning Integrated Control Electronics. Controls alarm, security, doors etc in the 9-5 and 9-3SS.
Vector ‘Sporting’ trim level, including eg aluminium dashboard and lowered suspension
Viggen the most powerful Saab 9-3, produced from 1999 to 2001 and sharing the B235R engine with the 9-5 Aero.
VIN Vehicle Identification Number
VSS Vehicle Security System. But, confusingly, also Vehicle Speed Sensor
XS Trim level denoting high-spec, non-turbo versions of the C900, NG900 and 9000
Wastegate Internal valve on the turbocharger which opens to limit boost pressure, driven by a wastegate actuator
WIS Workshop Information System, CD-ROM manuals used by dealers
WOT Wide Open Throttle
и это правда...
